Page 9 of 28 FirstFirst ... 789101119 ... LastLast
Results 81 to 90 of 280
Thread: Jay Jays Mk2 Project
  1. #81
    Suffolk UK
    Can you guys give me a parts list as to what you used to do the 5 stud conversion ?
    Any ideas if Golf VR parts would work on my Corrado ?
    Its looking good, sounds like an interesting project ......
    Oct 2006
    Theres two ways to do it carpoid, on a golf u can swap the subframe, control arms, swaybar, brakes inorder to use the vr6 steering knuckle. Alternatively ECS sell a 4-5 stud conversion hub which is simplier but u dont get the vr6 widetrack.
  3. #83
    Sep 2007
    yeah. it's really quite easy if you just do a subframe swap from a wrecked vr6. also, the rear stub axles are just a matter of loosening the calipers, a bolt and a bit of grease.
    i dont think the increased track would actually make that much difference, but primarily, because the vr6 has 288mm brakes(96-9, it's a lot cheaper than hunting abf cupra hubs, discs, calipers etc.
    but you've already got a g60.... that already has 280s...?
    87' MK2 GTI
    13' MK7 TDI
  4. #84
    if you go widetrack at the front and not the rear they reckon it handles really badly. but i guess you can just run spacers at the rear to make up the difference
    cheers brenton
    MK1 4door
    MK2VR6
    MK3VR6
    Transporter
    and untold wrecks
  5. #85
    Camden, Sydney
    Quote Originally Posted by carpoid View Post
    You need VR6 control arms, vr6 steering rack or rack ends. Vr6 antirollbar, Vr6 driveshafts, Vr6 hubs and the full hub assy with calipers and disks.
    The rear is as eay as swopping the 4 stud disk for a 5 stud one. If you want to incease the rear track you can use spaces, vr6 rear axle, or spacers under the stubaxle.
    If the Corrado has a Golf 2 or 3 style subframe and wishbones, you shoul be able to do it with G3 parts. I recon I`d leave the Corrado alone though, already 280mm.
  6. #86
    Camden, Sydney
    Quote Originally Posted by DVR68U View Post
    cheers brenton
    They reckon a VR6 in a Beeza or Mk2 handles badly and understeers on corners. Dont believe everything you read on the net.
    I reckon spacers under the stub axles is the way to go. Safer and not detectable by the fuzz.
  7. #87
    Aug 2007
    We used to shim the stub axles to stop the rear tyres scalloping on G3s, yeah and does beat the fuzz!!!
    Jmac
    Alba European
  8. #88
    Sep 2007
    where can i get a set? i was thinking about spacers but i know shims'd be heaps better.. in any case, to go widetrack on the back, would you need to swap over the rear axle?
    87' MK2 GTI
    13' MK7 TDI
  9. #89
    Oct 2006
    sydney
    jay jay my vr6 beeza has 10mm wheels spacers on the rear to compensate the front widetrack and it handles like its on rails
  10. #90
    Camden, Sydney
    Jay, we`ll make you some. You just get a piec of 10mm steel, drill 4 holes in it and use longer bolts to hold the stub axles on
    Cheaper and easier than changing the axle. Williams Beeza handles great and that has the beeza rear axle with the spacer and the widetrack front from the VR6. Same setup as your car will be.
