Page 2 of 12 FirstFirst 1234 ... LastLast
Results 11 to 20 of 113
Thread: Jarred's Mk 2 GTI & silly questions.
    clubgti forum under the 8v section have a wicked tuning guide and problem solving....well worth a look.
    sounds like the throttle cable needs replacing. gear bushes also.
    hunting idle, check all vacum hoses, one of mine was off and hunted badly. also mine will hunt abit when cold.
    if you want me to put up with mine one evening and we can have a nose about
    Velly
    '91 2.0 8v GTI
    Quote Originally Posted by DubSteve View Post
    I have wood thinking about you
    Jun 2007
    Eastern Suburbs Melbourne
    Thanks guys this is all good.
    Cheers Vel. I think you posted it before. I'll have to go have another look at it. Maybe I'll bribe Tim into helping me service it (properly!)
    oh and sorry, no coils and slammage for this. It's going to be my daily, and well, I'd rather spend the cash on other things
    i like volkswagens
    Sep 2007
    liiiiike a vr6 motor?
    87' MK2 GTI
    13' MK7 TDI
    Jun 2007
    Quote Originally Posted by jayjay View Post
    hahah... no. maybe. oh what the hell. i'm going to do a VR6T, dump it on air ride with some 17" RS's.
    I went for a brap round the hills today.
    Brakes definately need upgrading. mk 3 GL set up looks most promising so far, as that way I can still run 14's, which is important when it comes time to buy some semi's. Should also be able to locate most of the parts cheap.
    tyres are toyo's and hello! good stuff there. and recaro's! oh beautiful.
    Shift linkages need attention. I'm thinking about getting a short shift whilst I'm at it, I've seen them on GAP,but wondering if anyone else has any experience with any other short shift kits etc?
    Front shocks aren't performing great. I'm thinking Io might upgrade to koni adjustable inserts. Lift off oversteer isn't crazy, so I think the standard sway bars will do for now. Will have to check the bushes just to see if they're in good nick.
    Exhaust is droney as buggery, will have to look at that when i pop a mk 3 2L downpipe on.
    I had a bit of an issue with pinging at low RPM when the engine got warm (oil temp up to 110-115), hopefully tune up will sort this out. running 95 atm.
    I also think that the engine mounts need replacing. there's a bit of rocking when you get off the gas & between gear changes. Clutch is also slipping a little bit under hard accel in 2nd gear, but not noticable whenst brapping in the hills.
    i like volkswagens
    i had a short shift on my mk2 back in the uk, its fine be when the bushes wear they are a pain!!! i would look at putting a mk3 weight rod and new bushes and leave it at that (but its up to you really)
    my old engine ran 95 degs, not sure what the 2.0 runs at as the sensor is buggered but water temp seems fine.
    my pings sometimes but i know it does need a dam good tune, need someone with a timing gun and co2 reader to set it up as per tuning guide on clubgti.
    i have heard nothing but good things about putting on the mk3 downpipe. i really need to do this next month....keep you eyes out for a mk3 in the scrapy...i need some bits off one too
    still, glad your having fun
    Velly
    '91 2.0 8v GTI
    Got a weighted rod here Jarrad, yours for the cost of postage if you cannot find one local. Or I can send it back with the boys after the DOVW.
    EDIT Make the shift quicker your self. Take the bracket off the gearbox, the one with the ball on the bottom. If you reduce the height of it, the shift will be quicker. You can do it in a vice with a big hammer. A blowtorch for some heat helps too.
    Point Cook, Vic
    Quote Originally Posted by velly_16v_cab View Post
    there was a mk3 GL at centre rd wreckers last time i went there if thats the downpipe youre looking for. Was a month or 2 ago though. so might not be much left
    FOLLOW US ON FACEBOOK
    Oct 2006
    sydney
    hey jarrod i have a set of vr6 brakes kicking around at home make me an offer should bolt up just redrill the discs
    Sep 2007
    you should check out the crustyness of the coolant lines to the alternator. i flushed my system for the first time in its life about a year ago. we got about a kilo of mud out...
    new bushes and weighted shift are all you need for mk2 shifting pleasure. oh also that alignment tool
    ( 3104 ) + mk3 weighted rod + bushes = orsm. I've heard the USRT rose jointed kits are a bit of a pain to fit. but they apparently dont wear out... ?
    yeah the mk3 GL set up is definitely the cheap option. i got it as soon as it trashed my golf into a kerb... oops.
    87' MK2 GTI
    13' MK7 TDI
    Feb 2008
    Melbourne.
    Good buy Jarred..love those wheels, which I watched John clean b4 the pre-SEDF cruise..........I spotted you (or maybe John ?) in the beast on North Road, Huntingdale last Friday around 5pm on my way to Wilson's Prom (I was in my Subaru Outback..)
    Children(VW) who have left home, among others:1966 VW 1300 Deluxe Bug(Harbour Blue)1966 VW 1300 Steel Sunroof Bug(Ruby Red), 1971 VW 1600 S Bug(White) 1972 VW 25th Ann. Bug(Avocado) 2000 VW Golf Mk IV GTI 3 door(Metallic Black Magic), 1985 VW Golf Mk 1 GLS Cabriolet (Metallic Gun Metal) Current: 1985 Mercedes Benz 280CE Coupe(Midnight Blue)
