You can just look at google for the time in the UK.
I'm pretty sure you only need the passport info if you're importing the car as a personal import where you needed to own the car for 12 months before shipping it, to prove that you were in the same country as the car.
I had a G60 Corrado for 6 years mate, they're awesome, fairly tweakable, the cheapest mod is the chip and pulley one (smaller 68mm supercharger pulley and ECU chip), only $400-$500, it will take it from 160bhp to 190bhp, same as a 2.9l VR6 without the weight! A FMIC/Injectors/Exhaust will take it over 200bhp easily. You just have to make sure the charger is kept in good condition/serviced, and if you're running a chip and pulley i'd put an oil cooler in it too. Have a look at
www.g-werks.com and
www.bahnbrenner.com for more info and parts etc.
EDIT I just realised its already running a chip and pulley! Good stuff, that RSR outlet is good too, its the first hose coming out of the charger, normally theres a baffle box there to quieten the charger, but they always leak boost.
If i were you i'd definately ask him when the charger was last re-built and by who. Not too much of a drama if it hasn't been serviced for a while, but you need to find out so you can get it sorted if it needs it.
