Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 53
Thread: I'm back, now become WhiteMk2Gti
  1. #41
    Long overdue mini project - Triple Guage Setup
    All parts :
    cut and test fit the plate.
    go to sleep, to be continue.
  2. #42
    May 2010
    NQ
    Looks awesome so far!
    MK2 - *Insert list of dealer purchased extra's/standard features here*
    80 series - The MK2's BIG, Sooty, polar opposite...
    HAHAHA
  3. #43
    Ryan,
    Quote Originally Posted by ryana89 View Post
    I think I measured and found that there isn't enough space for 3 52mm gauge's to fit side by side. But I'd like to be proven wrong
    Ryans MK2 GTI
    I was trying to prove you're wrong -> golf-center-console | Turbocharged 16 valves
    but eventually perfer to have guages in ash tray location.
  4. #44
    May 2010
    NQ
    So I guess 3 across fit quite nicely (nice interior/setup in that car too might I add)
    I would happily use the ash tray, buuuut it holds all the screw/bolts/pieces that fall from my car
    I'd like too see your set-up (entire car) at nationals.
    HAHAHA
  5. #45
    Jan 2007
    I think mine suffers from the same use of the ash tray, lol.
    I was planning a three gauge install with some gauges I had lying around from an Alfa we used to own.
    07 GTI
    APR stage II
  6. #46
    Test run it will put it back in car soon.
  7. #47
    Jun 2007
    Eastern Suburbs Melbourne
    nice one, looks reasonable.
    (very mk 1 GTI inspired)
    i like volkswagens
  8. #48
    Put it back now still haven't connect the oil pressure sensor and wire though.
    I'm a bit disappointed with the temp gauge illumination, also has similiar issue that Ryan had, voltmeter only shows 12.x volt. Probably need to pull it out again and run a wire directly from battery to accurately monitor alternator output.
  9. #49
    New parts arrived, going to be a busy weekend
  10. #50
    May 2010
    NQ
    Supporting the A/C compressor is the most annoying part.
    Or did you get rid of it? It's not a bad job either way.
    HAHAHA
