Looks awesome so far!
Long overdue mini project - Triple Guage Setup
All parts :
cut and test fit the plate.
go to sleep, to be continue.
Parts for sale http://www.vwwatercooled.com.au/foru...ff-102387.html
MK2 - *Insert list of dealer purchased extra's/standard features here*
80 series - The MK2's BIG, Sooty, polar opposite...
HAHAHA
Ryan,
Ryans MK2 GTI
I was trying to prove you're wrong -> golf-center-console | Turbocharged 16 valves
but eventually perfer to have guages in ash tray location.
So I guess 3 across fit quite nicely (nice interior/setup in that car too might I add)
I would happily use the ash tray, buuuut it holds all the screw/bolts/pieces that fall from my car
I'd like too see your set-up (entire car) at nationals.
HAHAHA
Test run it will put it back in car soon.
nice one, looks reasonable.
(very mk 1 GTI inspired)
Put it back now still haven't connect the oil pressure sensor and wire though.
I'm a bit disappointed with the temp gauge illumination, also has similiar issue that Ryan had, voltmeter only shows 12.x volt. Probably need to pull it out again and run a wire directly from battery to accurately monitor alternator output.
New parts arrived, going to be a busy weekend
Supporting the A/C compressor is the most annoying part.
Or did you get rid of it? It's not a bad job either way.
HAHAHA
