nice detective work gays
Hi guys,
I am back! I tryed my car today for the first time with the 2.0lt motor, and I can see a big diference. There is more torque in low revs and more power. It still needs fine tuning but its working OK. If any of you guys want to do a conversion to 2.0lt, I can give you information on the process and parts needed.
Now, I have one more question:
I remember WV had recall for heating core, factory install bypass switch on heating core hoses. Anyway, my switch is blocked and doesn't work. I removed it and connected the hoses straight to the heating core. I want to know if anybody has experienced this also? If so, can you please advise me on a better alternative.
Thanks, Braco.
The bypass mod was done to stop them from bursting. The later cores were better made and didn't blow. You should be able to get some new ones from VW or maybe Imparts.
If the core bursts it can burn your passengers legs in extreme cases. Unlikely though and as Gavin says the later cores were better made, so if it has ever been changed, you should be ok.
I have heaps of the bypass bits here if you get stuck.
