Issues again,
this time its not engine related.
The bolt in the middle of my left hub (27mm, holds in the drive shaft and all that, you can see it if you take the hub cap off the wheel) keeps coming loose. It doesnt come off but it gets loose so that the hub moves around prity free.
I was just wondering if there was suposta be something there to hold it on. Maby a pin or lock bolt? If not then what is causing it to become loose?
Is it appropriate to double bolt it?
