Results 1 to 10 of 12
Thread: How to properly drain/flush the radiator
    86SA_GTI Guest
    As the title, can anyone please help me?
    The water is a bit gross.
    Feb 2006
    Camberwell, Victoria
    As far as I know...
    Take off the hose connecting to the bottom of the radiator, let it all drain out...
    Flush it out...
    Put back together, fill it up again with original vw coolant, and every now and again grab the top coolant hose and pump some of the air through...
    That's pretty much it...
    The usual trick is to revrse flush it with a hose pipe.
    There are products in the shop for cleaning out cooling system. I have never used any so can't vouch for their effectiveness.
    If you are doing a proper job then I'd drop the lid off the thermostat housing and drain the block as well. I would also disconnect a heater hose and quirt the hosepipe up ther as well.
    I usually put eveything back together and run the car to temp with plain water in it. Then drop that out before filling with coolant.
    Jun 2006
    Hornsby
    as above
    Peregian Beach
    Key points to remember.
    Don't poor cold (cool) water into a warm/hot engine unless the engine is running.
    Also when you do fill it up after emptying all the water out you leave the top off the expansion tank and run the engine (idling) until the thermostat opens and a good guide is to let it idle until the cooling fan comes on. This gets all the air pockets out. Once the fan is running and the coolant level is ok then screww on the lid.
    Oct 2006
    Good trick it to park it on a hill minus the cap and let it idle so the air bubbles flow up and out.
    May 2006
    I've never found this straightforward. If you want to drain completely you have to let the water go from both sides of the thermostat. But take care. When filling, the bloody thermostat can create problems. It only opens to allow circulation when its hot and since hot water only gets to it when it can circulate, it can stay closed when it ought to be open. You can easily be running the engine to pretty hot and dry inside the block. And since the temperature is measured on the radiator, and since the radiator is quarantined from the block when the thermostat is closed, you wouldn't know.
    If you drain from both sides of the thermostat then refill with boiling water and start the engine as soon as the reservoir bottle is full. If the level doesn't drop quickly then pay lots of attention.
    Once you've got the thermostat opening a good tip is to take a drive for 15 kilometers with a bottle in the boot. Then stop and let it cool down. When its cold the level should have dropped quite a bit because it will have pumped the airlocks out. Add the coolant then.
    Also, no one's mentioned it but its good practice to use demineralised water with the coolant.
    86SA_GTI Guest
    I have in a way, drain the radiator...twice. the radiator fluid looks like what a radiator fluids should look like. The question now is that the fan seems to not working. at what temp should the fan kicks in? I try to warm it until 3/4 of the temp gauge and the fan stand still.???? The fan itself works. i know cause when i switch the a/c on, the fan on. Any idea??? Thermostat?
    Get the fan switch and pull the connector off it. Short out the wires if there's two, if there is 3 follow them back to the positive terminal on the battery. That's the main power. Short that one to the other 2 in turn you should get a high and low speed.
    The switches are known to fail.
    VW says that anywhere on the gauge with the warning light out is normal. So maybe it isn't getting hot enough?
    On the other hand my MK1s fan is always running when I pull up, it has been over 30 most of the time since I started driving it which won't help.
    Oct 2005
    Dandenong North, Vic
    Quote Originally Posted by 86SA_GTI
    My radiator fan would kick in when the temp gauge needle was half way, although the temp would mostly sit at about 1/4 of the range.
    Whats the radiator temp sensor range you have ? What happens if you short the engine compartment temp sensor ? Its near the intake manifold.
Similar Threads
  1. radiator swap/upgrade
    By finemk1 in forum Mk1 Golf
    Last Post: 25-09-2006, 08:09 PM
  2. radiator
    By antinora in forum Mk1 Golf
    Last Post: 06-05-2006, 01:30 PM
  3. Rust in radiator - Overheating
    By worm in forum Mk1 Golf
    Last Post: 24-04-2006, 02:19 PM
