Results 1 to 10 of 15
Thread: How do I make a MK11 GTI go faster?
    May 2010
    what is the best way to make my Australian Golf faster without putting a VR6 in it?
    I have been told they are un-tuneable.
    Will removing the catalitic converter do anything?
    Dec 2008
    Bentleigh, Melbourne
    K&N air filter, i havent done it but people seem to like em
    Jun 2007
    Eastern Suburbs Melbourne
    Quote Originally Posted by Ricky D View Post
    ..Will removing the catalitic converter do anything?
    get you in big trouble if you get caught without it....
    Assuming you car is standard, i'd start off with a mk 3 2l down pipe and decent exhaust (inc a bigger/high flow cat) and maybe a good air filter.
    If you want to work the 8V a bit, common mods are 2L bottom ends with big valve heads & bigger throttle bodies. UK ECU's are meant to throw more fuel into the mix too. Apparently you can fit a bigger MAF on there too (from a 5 series BMW I think)
    A 16V would be nice, as they already make a bucket more power than our 8V's, standard!
    i like volkswagens
    Aug 2009
    Poor mans power modifications... Strip weight where ever you can!
    You've got about 98hp with the Aussie spec motor. A 2litre engine swap brings it up to around 110 which is similar to UK spec 1.8l motors but with more torque. Add the Mk3 downpipe and you've got a few more hp and more torque. You should be able to do this for under $500. Add a decent cam and some bigger valves and you're getting enough horsepower to start having fun without spending too much.
    While you have the exhaust pulled apart hit the cat a few times on the ground to dislodge all the rusted out bits which will help with the airflow.
    Paul
    Dec 2008
    Launceston, Tasmania
    I run a K&N, catback exhaust, 276 cam and HD valve springs, its alot faster than a stock mk2, the most restrictive part is the exhaust manifold though. Either bin the car or just get a metal vr6 one when you get the manifold done mate
    ----[ Finished the search for a mk2 GTI]----
    1990 Golf Mk2 GTI
    276* cam
    2 1/4 in straight through exhaust
    H&R springs on KYB shocks
    May 2010
    NQ
    My 1992 MK2 lacks a cat, but it passed roadworthy?
    Dec 2008
    Do they do emission tests in qld? you only need a cat if your car is built after july '88
    1990 Golf Mk2 GTI
    276* cam
    May 2010
    NQ
    I just had a read over the rules of QLD's emissions tests.
    From what I read of the QLD transport website, if your cars emissions are poor, you are 'suggested' to get it checked.
    Do you see a cat?
    Jul 2005
    Newcastle, NSW
    Get a chip from VW_Pilot from the Vortex.
