Results 1 to 5 of 5
Thread: Help with whatever the noise be
    May 2012
    Melbourne, VIC
    So every time i unlock my door i here a buzzing noise come from the back of the car, goes for about 20secs and then stops, my central locking doesnt work, so i was thinking this may be the problem! has anyone got the same noise?
    sounds more like a air compressor to be honest :/
    bardon
    the are pneumatic, check all your air lines
    Mar 2012
    Eastern Subs, Victoria
    Its the little air pump running making the noise probably. It's located in the boot on the left hand side, inside a foam case which is held on by a rubber strap.
    Jun 2007
    Eastern Suburbs Melbourne
    Quote Originally Posted by MK2GUY View Post
    Quote Originally Posted by Bamish1000 View Post
    These are correct. Sounds like the pump is still working, pull your door trims off and check for leaks in the system between both doors and the boot lock.
    Has the central locking ever worked?
    i like volkswagens
    May 2012
    Melbourne, VIC
    Bamish is right on the location
    and i can only assume it has worked! ill get onto fixing the LHS door handle and assembly, hopefully the reason for the noise will be uncovered!
