you've probably already done it, but i had to do this on my mk1 -
remove back seat to give more room
take off the interior trim
reach up inside and depress the catch release mechanism, directly behind the rear of the outer door handle.
your outer handle may not be broken! its possible that the door catch mechanism is out of alignment with the outer door handle and so wont contact the lever properly - thus you should leave tearing it off as a last resort
aydan
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
