Results 1 to 8 of 8
Thread: HELP - rear driverside door not opening
    May 2006
    hey guys,
    Door lock always needed a bit of work to open but not alot...now the door wont open from outside or inside......i can even hear the door catching.... so, any ideas on how im going to open the bugger ? ?
    thanks guyss
    Golfwise Guest
    You would have the child lock on so won't open from the inside and the exterior handle is no doubt broken so you will have to remove the door panel and reach in and open it that way.
    Once you deactivate the child lock you will be able to open it from the inside all the time but you are in for a outside handle
    May 2006
    but how am i gong to get the inside door panel off to do that ?
    Camden, Sydney
    E ither force the door trim off. Or take the chrome strip off the door handle, remove any screw that may be under there and rip it off the door. It will break, hopefully without damaging the door and then you can open it through the hole. A fit of rage is sometimes necessary when using this method.
    May 2006
    far out .....so i have to get the outside handle off and ill be able to open it ?
    any pics? ?
    Oct 2005
    Nowra, NSW
    pulling the door trim off would be easiest IMO depending what model you have, older the easier. It will be a hassel with the door shut but very do-able.
    Camden, Sydney
    I reckon its pretty easy to rip the lock off
    Gosford Central Coast NSW
    you've probably already done it, but i had to do this on my mk1 -
    remove back seat to give more room
    take off the interior trim
    reach up inside and depress the catch release mechanism, directly behind the rear of the outer door handle.
    your outer handle may not be broken! its possible that the door catch mechanism is out of alignment with the outer door handle and so wont contact the lever properly - thus you should leave tearing it off as a last resort
    aydan
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
Similar Threads
  1. Removing rear window mk2 gti
    By ausgolfer in forum Bodywork/Trim & Detailing
    Last Post: 19-01-2007, 10:13 AM
  2. Height Adjustible rear beam.
    By Golf Loon in forum Tuning and Performance (inc ECU upgrades)
    Last Post: 26-06-2005, 09:51 PM
