ok i have just got a new relay from the helpful guys at vw imported and fitted it and it is still doing the stupid thing.
any other ideas
it is really starting to s**t me now
relays are available from any motor spares place, narva etc will make ones that will fit. Take your old one in to double check compatibilty if insure.
73 mini clubman supercharged money pit
any other ideas
Im going with its the stalk, can you explain what you have done and the syptoms again,
have you fiddled with the wiring? there are 4 wires from memory.
if you have eliminated,
1 - wiring (check resistance from wiper motor end to the stalk plug end)
2 - relay
then it may be your stalk.
It's quite simple, your car is possessed
My build thread here: 1.6 sr into 1.8T http://www.vwwatercooled.org.au/foru...-8t-63249.html
Having looked at the wiring diagram. I'd be looking at the stalk too now. Assuming you don't have one too try in there. You could check the stalk out to prove it is faulty.
With the stalk in the OFF position, you need to check for continuity from the green/black wire at the motor, to pin 6 at the relay base on the fusebox. These are marked if you look closely.
With the ignition switch on, make sure you have power on the black/grey wire at the motor.
I think as well that pin 6 at the relay should have power there with the motor running. You'll only get the wipers to run on the fast speed, with the relay removed.
Have a look at those 3 and let me know what you see.
