Results 1 to 10 of 17
Thread: help please
tud82 help please 17-07-2009, 03:26 PM
AusScare I think mine did this a few... 17-07-2009, 03:28 PM
tud82 hey mate cheers have tried... 17-07-2009, 04:25 PM
Golf Loon I`d think relay or stalk. If... 17-07-2009, 08:56 PM
Spyda hahahaha dirty 17-07-2009, 09:36 PM
Stan sounds like the relay is... 17-07-2009, 10:04 PM
tud82 this is probally a stupid... 18-07-2009, 10:17 AM
h100vw In the fuse box. Cant... 18-07-2009, 10:33 AM
tud82 cheers will try that and are... 18-07-2009, 11:13 AM
h100vw I doubt it. When you find it,... 18-07-2009, 11:20 AM
the scotsman relays are available from any... 18-07-2009, 12:11 PM
tud82 ok i have just got a new... 18-07-2009, 01:09 PM
h100vw I wouldn't expect any old... 18-07-2009, 02:05 PM
tud82 Cheers gavin Have changed... 18-07-2009, 03:19 PM
tommymac Im going with its the stalk,... 18-07-2009, 04:09 PM
Stan It's quite simple, your car... 18-07-2009, 04:30 PM
h100vw Having looked at the wiring... 18-07-2009, 06:00 PM
    Quote Originally Posted by the scotsman View Post
    relays are available from any motor spares place, narva etc will make ones that will fit. Take your old one in to double check compatibilty if insure.
    I wouldn't expect any old shop to carry a VW compatible relay.
    I'll pull the Haynes later and give you some more things to look at. I suspect something a bit harder. Are you any good with a multimeter? Do you have one?
    Apr 2009
    Cheers gavin
    Have changed on relay that i pulled out and wipers stopped working but when put new one in there was no change
    i should have a multimeter around, so any new ideas would be great
    cheers mate
    The Mk2 GTI Baby
    Jun 2006
    Hornsby
    Im going with its the stalk, can you explain what you have done and the syptoms again,
    have you fiddled with the wiring? there are 4 wires from memory.
    if you have eliminated,
    1 - wiring (check resistance from wiper motor end to the stalk plug end)
    2 - relay
    then it may be your stalk.
    Jul 2009
    Geelong, Victoria
    It's quite simple, your car is possessed
    My build thread here: 1.6 sr into 1.8T http://www.vwwatercooled.org.au/foru...-8t-63249.html
    Having looked at the wiring diagram. I'd be looking at the stalk too now. Assuming you don't have one too try in there. You could check the stalk out to prove it is faulty.
    With the stalk in the OFF position, you need to check for continuity from the green/black wire at the motor, to pin 6 at the relay base on the fusebox. These are marked if you look closely.
    With the ignition switch on, make sure you have power on the black/grey wire at the motor.
    I think as well that pin 6 at the relay should have power there with the motor running. You'll only get the wipers to run on the fast speed, with the relay removed.
    Have a look at those 3 and let me know what you see.
