Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: help please
    Jul 2007
    Earlwood Sydney
    relays are available from any motor spares place, narva etc will make ones that will fit. Take your old one in to double check compatibilty if insure.
    73 mini clubman supercharged money pit
    Apr 2009
    ok i have just got a new relay from the helpful guys at vw imported and fitted it and it is still doing the stupid thing.
    any other ideas
    it is really starting to s**t me now
    Quote Originally Posted by the scotsman View Post
    I wouldn't expect any old shop to carry a VW compatible relay.
    I'll pull the Haynes later and give you some more things to look at. I suspect something a bit harder. Are you any good with a multimeter? Do you have one?
    Apr 2009
    Cheers gavin
    Have changed on relay that i pulled out and wipers stopped working but when put new one in there was no change
    i should have a multimeter around, so any new ideas would be great
    cheers mate
    The Mk2 GTI Baby
    Jun 2006
    Hornsby
    Im going with its the stalk, can you explain what you have done and the syptoms again,
    have you fiddled with the wiring? there are 4 wires from memory.
    if you have eliminated,
    1 - wiring (check resistance from wiper motor end to the stalk plug end)
    2 - relay
    then it may be your stalk.
    Jul 2009
    Geelong, Victoria
    It's quite simple, your car is possessed
    My build thread here: 1.6 sr into 1.8T http://www.vwwatercooled.org.au/foru...-8t-63249.html
    Having looked at the wiring diagram. I'd be looking at the stalk too now. Assuming you don't have one too try in there. You could check the stalk out to prove it is faulty.
    With the stalk in the OFF position, you need to check for continuity from the green/black wire at the motor, to pin 6 at the relay base on the fusebox. These are marked if you look closely.
    With the ignition switch on, make sure you have power on the black/grey wire at the motor.
    I think as well that pin 6 at the relay should have power there with the motor running. You'll only get the wipers to run on the fast speed, with the relay removed.
    Have a look at those 3 and let me know what you see.
