Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Help needed with 8v RV
    Jan 2012
    St Albans, Victoria
    Quote Originally Posted by GeorgeMK1 View Post
    Come on Peter, still haven't started it yet? haha need a hand bro?
    I'll be ok George, once I roll it off a cliff. but I think those dellortos are looking good for it ATM.
    Oct 2013
    Tasman,Nelson ,New Zealand
    Lots of wierd answers ,IF you are real lucky the ecu won't be toast but it sound like it,ALL earths have to be spot on and connected to clean contacts period.
    VW addressed this problem in the very late mk2's and the first mk3's cause there were issues with the first dijifant cars,the ecu suffers because it needs a good earth,if not they cook and overfuel or work @ all.
    MM no cold start injector in the dijifant ,its done by the ecu and gets a signal from the temp sensors.
    No brown wires will ever have power as they are for earths or ground and are part of that system,bad earths can cause a number of other problems with the engine also.
    1987 Golf GLI Wolfsburg Edition,full gti spec 3a Audi 2 litre on dijifant 2
    1989 Corrado 1.8 16v KR manual (02a) black 15x7 RH cups
    1987 Golf GTI original 3 owner in white.
    Audi Quattro,and various Porsches
    Jun 2012
    Auckland, NZ
    Quote Originally Posted by Watercooled View Post
    Yes true good point, I noticed that after I posted. Got mixed up with my mom's kjet car
    Oct 2013
    [QUOTE=Petska84;1007878]I'll be ok George, once I roll it off a cliff. but I think those dellortos are looking good for it ATM.[/QUOTE
    Yep the carbs may seem like a solution ,but you will spend a lot less money sorting out the dijifant issues than going to carbs,yes they go well but are very costly to do right and will drive you nuts unless you know LOTS about them trust me.
    Your fuel consumption will increase and you will find air cleaners very hard to set-up @ the inlet side of the motor and more don't go there unless you like tuning more than driving.
