aint it just a standard size? you can get it from repco if needs be! the only thing that is an odd size is from the return to the block from HVAC
Hi,
Hoping someone here may have a spare water hose they can part with for fair price $$.
cause Im leaking water and need to drive somewhere on the weekend.
part number is 535 121 109
goes from head left side to expansion tank.
Engine 1.8 lt 8 V
Can get one through VW parts, but not in stock.
Hoping some might have one and I might get it quicker.
Thanks all
locky
07 GTI
APR stage II
I've tried supercheats and Autobahn and neither had the hose size i needed.
Funnily, neither had a replacement listed in their catologues!
It aint safe to just get a straight bit of pipe, Because off the bend , it kinks way to much.
Tried that.
07 GTI
APR stage II
http://www.foreigncarpartsonline.com/
They have it for 27 us so around 50 with shipping and AUS
07 GTI
APR stage II
Whats your location ? GolfLoon should be able to help you out.
If your in Vic try http://www.mercwreck.com.au/index.php they are wrecking some Golfs and Seat with 8v motors, but they are a bit pricey.
I would rather get a new hose and I find http://www.autohausaz.com/ to be relatively cheap and fast delivery from the states. (within a week)
MK2 GTI G60
Update your location. And tell us what year model the car is.
Plan B, check out your local Pirtek place, they can make anything and the prices are pretty good. They made a joint for me for about $30 which saved me buying a VW genuine part at $280...
Should be the same as Golf 3 2L or 1.8 manual.
I have some second handies if you get stuck.
Or my Homie Beau is on the Gold Coast. He is a VW mechanic and probably has one lying around. PM me if you want his number.
