Results 1 to 10 of 82
Thread: My new Mk2.
Threaded View
    Feb 2007
    My new Mk2.
    Thanks to Matt, Dad and my gf I got myself another mk2, one that isnt smashed. The first thing i did was cut myself on the gear nob, off to a good start i think.
    I got it for a fair price, the same price i paid for the red one and funnily enough it is in about the same condition as when i got the red one.
    Here are a couple of pics I snaped today before i got stuck in to it.
    It looks alot worse in person haha. It very very dirty in side and out but it goes prity hard.
    I got it with a 2L bottom end, rebuilt box and vr6 brakes. I have also been told it has uprated sway bars and shocks but i have to double check these things. Its prity amazing to drive compared to the red one, ALOT more power.
    So far i have:
    -changed the mirrors with working ones
    -fixed the passanger side central locking
    -fixed the shift linkages
    -fixed the horn
    -re-atached the bumper and spoiler (still needs work)
    -changed the vacume lines
    -changed the ISV (but the idel is still crap)
    -changed some of the cooling pipes
    -swaped the air box out (too many holes)
    -changed the wipers
    -re atached some bits and bobs
    Things that need doing off the top of my head:
    -front engine mount
    -at least 2 new tires
    -timing
    -the rear end needs to be redone, the hatch isnt painted on the inside and has been badly repaired
    -the car steers by itself sometimes when your on the gas
    -brakes need bleeding
    -new head lights and grill
    -idel issue
    -crack in the windscreen
    -cosmetic stuff
    Im sure the list will get bigger once i book it in for a road worthy check.
    The mods that will be done:
    -ss exhaust including downpipe
    -sterio (can you say 140db)
    -interior will have some minor work done
    -coiloveries
    -electric windows
    -alarm
    etc..
    .....and ive lost my train of though
    I will keep this page updated as i go along, hopefully it will turn out a bit better than my red one.
    *EDIT*
    Things to do for RWC:
    - windscreen
    - wipers DONE
    - parkers are blue DONE
    - dash lights all need to work
    - front grill needs to be secure DONE
    - no number plate globes
    - secure and mount radiator DONE
    - no timing belt cover DONE
    - front shocks
    - exhaust mounts DONE
    - rear wheel bearings
    - secure wires under front bar
    - passenger side seat is loose DONE
    - wash motor and repair oil leaks
    - p/s drive shaft boot
    - drive shaft seals
    - p/s lower side skirt trim
    - refit fog light DONE
    - 2 new tyres DONE
    - front rotors
    - rear rotors
    - p/s tie rod end boot
    - possible water leak
    - front engine mount DONE
    MK1 GLS 3door
    A4 B7 2.0T
