86gti heaters in da MK2 03-05-2006,
09:47 PM
joshyd-mk2gti my heater works great.... 03-05-2006,
10:53 PM
Guest My '86 worked great. 04-05-2006,
06:20 PM
86gti you can hear the fan... 05-05-2006,
12:06 AM
aliasmk2 g' day there my mk2 fan &... 05-05-2006,
11:40 AM
Golf Loon I always suspect the heater... 05-05-2006,
05:33 PM
Guest OK, I have had a similar... 05-05-2006,
05:34 PM
Guest Welcome! 19-05-2006,
01:02 PM
moto Re: Welcome! 20-05-2006,
10:25 AM
86gti yea checked all that... 25-05-2006,
11:18 PM
86gti ahhhh, no havnt looked... 28-05-2006,
08:19 PM
OK, I have had a similar problem before with a '88 16v from SA.
There is a slider that controls which vent the air comes out of that operates vacuum servos. It works by a rubber piece with holes in it sliding across and connecting different ports to open the various flaps.
The one that I had was not drilled correctly so that when a vacuum was applied to the rubber pad it closed off a minute piece of rubber and blocked the port. It took a while to find as at first we were blowing through it which opened it up. Then when I sucked on it I noticed that it closed up and blocked the vacuum.
There is a test procedure for it in the Bentley workshop manual.
- You may not post replies
- You may not edit your posts
Forum Rules
