Results 1 to 10 of 11
Thread: heater wont blow hot air!!
    Sep 2008
    melbourne/woopwoop
    just go my mk2 back after a while, the fans still work, and aircon, but the heater wont blow hot air, kind of frustrating with melbourne weather being inconsistant, any ideas??
    85' MkII 1.8 K-jet(small Bumpers) SLAMMEDDD!! ( sold )
    91' MkII GTI sold!
    Mar 2007
    sydney
    id take a stab at heater core....
    mk4 the mods begin for round 2 hahahha
    Sep 2006
    Thermostat
    Get the car up to operating temperature, open the bonnet and feel the two rubber pipes that go from the motor to the firewall (and on the the heater). The pipes are about 2cm in diameter. Both of them should be warm/hot. If not, the water isn't going through your heater and you won't get any heat out of it.
    If only one is warm you've got a blockage somewhere that isn't letting hot water flow through the heater and out via the 2nd rubber pipe.
    Paul
    Sep 2008
    melbourne/woopwoop
    cheers guys i will check that out today.
    91' MkII GTI sold!
    Feb 2007
    We checked it and both heater core pipes get hot but still not hot air.
    MK1 GLS 3door
    A4 B7 2.0T
    Dec 2008
    Launceston, Tasmania
    Quote Originally Posted by Spyda View Post
    Are you losing any coolant at all? Maybe the heater flap is broken, is it still blowing cold air when you switch it to hot or does it change a little? I think the heater flap in the golf is vacuum fed so possible a leak or a broken flap...
    ----[ Finished the search for a mk2 GTI]----
    1990 Golf Mk2 GTI
    276* cam
    2 1/4 in straight through exhaust
    H&R springs on KYB shocks
    Sep 2006
    Quote Originally Posted by VwJunkie View Post
    Are you losing any coolant at all? Maybe the heater flap is broken, is it still blowing cold air when you switch it to hot or does it change a little?.
    The flap is a common problem from what I hear. This has happened to mine ARGH
    Dec 2008
    Quote Originally Posted by Bboy_Sparx View Post
    Yeah i know we are having a few probs with them on the falcons so most likely to be the same problem here, gonna be a dash out job to get to it
    1990 Golf Mk2 GTI
    276* cam
    Sep 2008
    melbourne/woopwoop
    Thermostat
    i rekon you my be right, when the car idles in traffic and warms up to half, the heater blows hot air, when i start to drive the temp gauge cools all the way down to the bottom, and the heater goes cold.
    91' MkII GTI sold!
