Results 1 to 10 of 10
Thread: Heater bypass valve
    Heater bypass valve
    Any one know if our Australia released Mk2 Golf has heater bypass valve ?
    I'm still trying to trace down why my heater has no hot air, read some thread in oversea Golf forum, one possibility is heater bypass valve playing up. But I can not see any valve in my Golf heater in/out pipes.
    syncro Guest
    They don't have one. These are only on Golf 1s.
    Canberra
    More likely to be gunked up heater matrix. Common flaw, and factory recall in the Mk2... What year???
    Euro look 2... Mk2 love!
    It is 90 built, 91 registered. I don't know if it has been covered by the recall. The heater stopped working after I flushed the coolant with running tap water through the expansion tank. I'll try disconnect the in/out hose this w/e and see if water can flow through the matrix.
    syncro Guest
    Quote Originally Posted by mrgolf
    The factory recall was to protect against leaks burning the driver's legs.
    May 2006
    The coolant flows through the matrix continuously in the Mk11. That is, if it were blocked then you would have a serious overheating in the engine, not only in the heater. The heater cores are starting to fail from age but if that goes, you get coolant in the car, steam inside your windows and, again, engine overheating from loss of coolant.
    If your engine isn't overheating then its possible its running cold - thermostat stuck wide open? Otherwise, its almost certainly got to be a problem in the heater unit itself, fan, flaps, vacuume ... that sort of area.
    Unhappy
    Thanks, Moto
    Thermostat was replaced 6 months ago, unlikely it is bad.
    No overheat problem
    No coolant in the car
    No steam inside the window
    Probably need to pull the dash out to check the heater box
    Camden, Sydney
    I reckon it will be the flap controlled by the cable, that is not letting hot air into the car. Check your sliding heater switches and then up under the dash to see if the heater flap is being opened.
    Canberra
    Quote Originally Posted by moto
    Oh yeah, forgot that bit...
    syncro Guest
    Quote Originally Posted by Golf Loon
    That's what it sounds like to me.
Similar Threads
  1. Heater Repair
    By moto in forum Mk2 Golf & Jetta
    Last Post: 29-01-2007, 01:06 AM
  2. 90' Passat Aux air valve probs
    By ausgolfer in forum Passat (B4 & B5)
    Last Post: 27-08-2006, 07:26 PM
