Hey all,
The Mk2 is having some issues at the moment, basically the battery started by going flat one night...
Then battery was swapped to another I know works, it fixed the issue and ran for a few days, now in the last 48 hours, it has died again when the car was just sitting, roll starting the car has worked to start it both times it died. From here we let it charge and it just continually died, now when you go to crank it after charging the battery on a charger and trying 3 different batteries the electrics just flicker in the car and the starter motor makes a loud clicking sound.
Does this sound like a starter issue to you???
Or what else would you think sounds suspect?
Thanks,
Aaron.
