I'd check the connections at the terminals to ensure the cable and the terminals (this is the terminal on the cable itself) are well seated. I had this same issue and it was the positive cable loose in the pole terminal - replaced the earth and + and never looked back.
Good luck.
It is not really a voltage drop, this is sounding like a broken circuit.
What happened in the carpark, how did you get it going?
