Results 1 to 10 of 12
Thread: gti mk2 91
    Sep 2007
    perth western australia
    Red face gti mk2 91
    anyone in wa i could speak too about my car !!
    Aug 2007
    Mate we are from all over and there is plenty of people on here more than willing to help mate. Whats up with ya Dub mate?
    Alba European
    Sep 2007
    hi mate just latley my car is back firing when i go through the gears when i give it acceleration the injectores have been serviced , a new k/n filter with the inside taken out of the airbox , any suggestions, cheers
    Penrith, NSW
    I might be totally wrong here but if your filter is sucking up more air it might be causing the car (ECU) to run rich and therefore back firing, dunno, some of the more technical guys here will help im sure
    1986 MkII Golf GTI 16V (Sold), 2005 MkV Golf GTI (Sold), 2007 Polo GTI (Sold), 2011 Polo 66TDI (Selling), 2012 Passat 125 TDI Bluemotion, 2013 Scirocco R (Due October!)
    Sep 2007
    yeah thats what i was thinking to i might put the stock filter back in and wait till i get a free flow exhaust system
    Oct 2006
    usually with backfiring the problem lies with the spark plugs or leads. did it start to happen recently? when were the last time they were changed?
    Sep 2007
    can i buy spark plugs that have been set for this model ?i have not done leads for two years and i cant find any record in my paper work,i should change them i reckon
    Jul 2006
    Perth
    Hey dubsweeper, I'm from perth
    out of interest which mechanic do you normally use?
    de
    Sep 2007
    joe at golfwagen has done most recent stuff like gearbox and injectors.
    Apr 2006
    Asaka-shi Saitama Japan (from Tassie)
    Some AFMs (air flow meters) don't like aftermarket filters.
    Not familiar with the AFM on the Bosch system in the mk2, but im pretty shure they are a bit like the nissan Vane type ones.
    you can pop the black top off them and add a bit more tension to the spring to compensate for the increased airflow.
    Blugs and points will cause intermitant firing thru the rev range.
    if its back firing between shifts etc, its more than likely a fuel/Air delivery problem, steming from the AFM
    Try you old filter set up and see if it stops doing it first tho.
    Cheers, Benny
    www.axesent.com.au
