What year Mk2? Is it an Aussie one?
Drive shafts from a Cordoba are the same.
Master cylinder from Cordy will work, but may not have the same number of outlets. It does have T piece brake line splitters so you could use the whole line with them attached.
Brake Booster from Cordy wont work, the inner end is different.
I have a Mk2 booster here if you get stuck.
