Results 1 to 10 of 10
Thread: Gti 8V problems
    Jun 2012
    Port Stephens, NSW
    Gti 8V problems
    Hello, I have a 91 4 door auto Gti so probably the least desirable mk 2 but have plans to re power and restore it at a later date.But will probably drop it with some new wheels to keep me happy for a while. Got to finish another project before I tackle this one. But for now its my daily driver and I'm trying to keep it on the road. I have just replaced all the hoses as they were like putty, thermo switch, plugs, filters etc. It's dropping coolant though, when it sits after a good run. It doesn't over heat when driving or idling, its just when sitting hot it drops coolant. I'm pretty sure its coming from the over flow under the reservoir. The temp gauge never really gets over a quarter is this normal? It also runs really rough after a cold start. Compression test was all good. I have a mechanic friend who's doing the work on it after 2 garages couldn't fix a couple of minor problems but just made them worse. Step by step we are isolating the little problems but I thought if you guys had any ideas that would be great. I would like to work on it myself but just don't have the time. Any help would be awesome.
    Feb 2009
    Please Enter Location
    Overflow tank cap !!
    Jun 2012
    Port Stephens, NSW
    Yeah the tank cap seems o.k as system is not losing pressure but may be due for replacement anyway.
    Apr 2006
    VW Race HQ - Sydney
    if its leaking it is loosing pressure . Have a look at the threads too as thats the actual seal (apart from the o-ring)
    Bug_racer supports the rebellion of the euro revolution
    May 2012
    Melbourne, VIC
    check ur housing, from the radiator to the engine, mine was ****ed and was leaking from there.
    May 2010
    NQ
    Have you got a Bentley repair manual for it yet?
    MK2 - *Insert list of dealer purchased extra's/standard features here*
    80 series - The MK2's BIG, Sooty, polar opposite...
    HAHAHA
    Quote Originally Posted by 67slider View Post
    No, it's not normal.
    Apr 2008
    I'm thinking it could be the thermostat? It's stuck open so it can't get up to temperature.
    As for your leaking, maybe just buy a new hose kit from the UK and kill all birds with one stone
    Jun 2012
    Port Stephens, NSW
    Thermostat! All hoses replaced and all fingers crossed.
    Jun 2012
    Port Stephens, NSW
    Thanks for all the advice guys! Thermostat was poked, replaced all the hoses and thermo switch. Now to find some wheels and drop it a bit!
