Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Gt28Rs is now on and running
    Jun 2006
    Hornsby
    Well its on about 15psi and it silly fast,
    the engine specs are
    AGU with qpeng tune.
    Stock internals etc etc
    630cc deka's
    intercooler etc etc all other specs will saved for the show.
    90 GTI Mk2 1.8t soon to be with GT28rs
    Aug 2009
    Quote Originally Posted by POLARBEAR666 View Post
    I think you should have gone for a GT30/40 as they can have external gate setup and often spool up just as well as a smaller turbo but with no real limit on the top end potential unless you plan going past 25psi on a 2L turbo.
    I am sure it will happen now that the bigger turbo bug has bitten. When I changed from GT25 to GT30/40 I gained bottom end because the 4 inch smooth intake and smooth exhaust housing with no internal gate were that much more efficient
    The 28RS the car is running has a rear housing with no internal gate (running a 38mm tial). The exhaust path is very smooth.
    There is simply no need for a larger turbocharger, as it is (with a rich tune) 3rd/4th gear wheel spin is an issue.
    biggest sleeper.... ever!
    Aug 2009
    Yep, I can personally vouch for this car, it is a true animal.
    I drove it on the weekend and it is a scary little machine- if you so much as look at it the wrong way it WILL bite your nuts off!
