Results 1 to 9 of 9
Thread: grease
    Jun 2006
    Hornsby
    grease
    hey guys whats yours views on ze grease.., im just re-greasing my output flanges - I need some special CV grease anyone use anything especially good?
    cheers
    Jun 2006
    Melbourne, Victoria
    Make sure you use CV grease and you wont have any dramas. Dont just use normal grease.
    Buy a tin of something that says CV grease on it.
    Yep this is true.
    CV Joint grease has different properties to other grease especially in the low friction, extreme temperature & pressure department & should not ever be replaced with normal grease.
    Molybdenum disulfide is the main ingredient you should be looking for when choosing a good CV Joint grease.
    Try Castrol LMM Grease.
    Normally I just use the grease that comes with the CV Joint rebuild/boot kit's, but that's just as good.
    I was also tought to apply this grease to inside the CV Boot's to keep the rubber soft which mean's the boot's last longer.
    Oct 2006
    dont listen to them.
    use this grease, just make sure you do it right...
    Quote Originally Posted by fuzion View Post
    Ha ha. Good call. Got a kick out it.
    I reckon John may have some CV joint grease in his undies. He moves pretty smoothly & I reckon his undies would be under extreme pressure!
    Camden, Sydney
    Isnt that pic from saturday night fever, not grease?
    Sep 2007
    definately not. i should know
    87' MK2 GTI
    13' MK7 TDI
    Oliver Newton John was in Grease, not SNF.
