Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: GOLFII is down.
    Feb 2007
    GOLFII is down.
    Only had the b....d for a week.
    Took it to the car wash and the guy that worked there insisted on showing me how to wash the engine. He said it would all be good. I didnt like it but hey im an idiot.
    He said leave the engine running so i did, then as he was washing it, it started to choak, i gave it some gas but it still clonked out. He said it would be fine in a few min, told me to just wash the car and then it would start up no worries. SO i washed the car, turned the key and it wouldnt turn over, made all the usal sounds but didnt turn on. So i pushed it in to the shamy area and looked at a few things pretending i knew what i was doing. Drying the leads and spark plugs.......then i called dad haha.
    Waited till he got off work and he sorted it out by drying the leads, plugs and dizzy, as i did but he did a better job. started up realy rought but got there in the end. I drove it to my parents cafe do get some dinner. It was ok, but running a bit rough, i think it was droping a cylinder randomly. Had dinner, went back to the car and the ****er wouldnt start, well it would, but it would sit on idel for about 3sec then drop to about 500-700rpm, sounding realy bad, again like one cylinder wasnt going and when you would hit the gas it would cut out.
    Any ideas? Just wet leads?
    Moral of the story is, dont do dumb ****.
    BTW i got new leads, some Top gun MAX something or other, they said they didnt have anything above 7mm coz it couldnt fit (even though one of my leads was 8mm anyway from previous owner) so i got some MAX, low resistance leads. Any reviews?
    MK1 GLS 3door
    A4 B7 2.0T
    Jan 2008
    Melbun
    i know it sounds dumb but try charging the battery. if its completely dead from trying to start it so much it might not run properly i had the same symptoms on my mk2
    2x Caddy, 1x Ducato
    Feb 2007
    Fixed it and returned the 7mm MAX leads and got 8mm instead.
    The problem was the two sensors on the front of the engine attached to the radiator pipe. I think if you have a mk2 youll know which ones im talkin bout.
    When i bought the car one of the plugs was missing and the other one was connected to the blue sensor (closest to the radiator). The way i fixed it was by simply unpluging the sensor. It idles alot higher but it got me home, the idle was at 1k rpm but now its at 1.25k rpm sometimes higher.
    What i wana know is....wtf happend to the other plug? What are the sensors for? and why doesnt it work with only one sensor pluged in? is it dangerous to the engine? etc. etc.....oh and how do i fix it, i cant find the other plug anywhere btw.
    Help?
    MK1 GLS 3door
    A4 B7 2.0T
    Oct 2005
    Dandenong North, Vic
    Blue sensor goes to the ECU and the black runs to the gauge cluster inside.
    The blue sensor is usually disconnected for timing check/adjust (tells ECU service mode or something) Without it ECU wouldnt know what temp your motor is.
    MK2 GTI G60
    Feb 2007
    Quote Originally Posted by aussieg60 View Post
    Yeah i feel its very slugish below 2k rpm and kicks in very noticably after about 2.5K. When I do hook up the blue plug the car doesnt work. Idel drops to 750rpm, strugles and if you touch the throttle itll turn off, so i leave it unpluged.
    Any ideas? Sugesstion? Whats a good vw mechanic to go to?
    EDIT*
    The one that is connected to the guage cluster? What is it suposta send? When i plug it in to the blue one the MAF thingo still shows water and oil temp etc.
    MK1 GLS 3door
    A4 B7 2.0T
    Check the dizzy is dry for starters
    Feb 2007
    Quote Originally Posted by evorobin View Post
    Yep thats all fixed now. Since i bought the car it has been missing a plug for the 2 sensors and the car doesnt work properly with only one pluged in.
    MK1 GLS 3door
    A4 B7 2.0T
    Oct 2005
    Quote Originally Posted by Spyda View Post
    Your MFA will only show you oil temp which is a different sender.
    You can check that the temp senders are working proper. You would need to measure their resistance and follow the chart in the Bentley for that particular temp. (ie. you would get a specific resistance reading at that temp range)
    I would just replace them, they not that expensive.
    So you are missing a plug on one of the wires ? Buy a new plug and wire it in. Part number should be on 1 of the connectors you have connected.
    I wouldnt think the car would run proper with the blue sender disconnected.
    MK2 GTI G60
    Feb 2007
    With the blue conected the car doesnt work properly. With it disconected it just lags below 2krpm and idels a bit high. Do they both sensors have to be pluged in for them to work? Is that why the car doesnt work properly when one is connected?
    Im not missing a plug for one of the wires, im missing the whole wire and plug.
    I have replaced both sensors long ago, didnt help anything.
    Any ideas?
    MK1 GLS 3door
    A4 B7 2.0T
    Post a picture of the engine. It should have 2 sensors to run properly Like Aussieg60 says.
    It may have had another engine fitted in the past and not hooked up correctly.
