Results 1 to 7 of 7
Thread: Golf mk2 stuck in 3rd gear
    Hello
    I need some help
    Last night I was driving and I shifted down from 3rd gear to 2nd and went bk up to 3rd and now it's stuck in 3rd gear...
    Do I need to replace my gearbox ? If so where can I buy one or who's selling a gearbox?
    Cheer
    Oakleigh VIC
    I've had this happen a few times, and it's always required the gearbox to come apart.
    It's something to do with the 3rd gear selector traveling too far and some pawls popping out.
    Replacing the box is going to be cheaper than rebuilding it.
    A MK3 gearbox might be a good option, maybe have a think about what sort of ratios you'd like in the new box.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
    Nov 2009
    As Pete said, if you Google 'stuck in 3rd gear broke vw' it explains how to fix.
    Gav
    Jun 2011
    Would get to many results with broke vw i think
    Nov 2009
    That's true but I put 'quote' marks around the text I meant, I'll make it clearer next time.
    Cheers for that peter
    If I was going to put a mk3 gearbox in it, what else do I need to change in the car..
    Oakleigh VIC
    The mk3 8v gearboxes are the same, nothing major to change, maybe a different sender connection but that's about it, just move you mk2 linkages and brackets across.
    Double check the CVs , they should all be 100mm diameter.
    It would be worthwhile to do the clutch while you're in there.
    7? MK1 Caddy
    12 Amarok
