Page 9 of 14 FirstFirst ... 7891011 ... LastLast
Results 81 to 90 of 140
Thread: Golf mk2 Gti
  1. #81
    Jan 2007
    140hp from a 8v is awesome !!
    I'd be happy with 120hp
    Although I'm more inclined to look at a 1.8T conversion and try for 180hp once I go looking for more power.
    Looking forward to see what you have in store!
    07 GTI
    APR stage II
  2. #82
    120 Should be achievable with the 270 cam, Euro downpipe, 2 litre block and some porting of the head. More than that and you're going to need a hotter cam, bigger valves and extractors.
    270 cam is supposed to be the best for normal day-to-day driving. That's the one I'll be fitting to my MK2.
    Paul
  3. #83
    Oct 2010
    Does anybody have a picture of the belt setup? Putting everything back on and just want to make sure I have it the right way.
    91' Golf mk2 GTi 1.8t (soon to be gtx3076’d)
    Golf mk2 GTi 8v
    02' Audi S3 (soon to be gtx3076’d)
  4. #84
    Oct 2010
    Quote Originally Posted by RedMk2Gti View Post
    Would this help ?
    Photos of v belts setup
    Exactly what I was looking for. Thank you!
    Golf mk2 GTi 8v
  6. #86
    Jan 2007
    I need to read back through this thread again !
    Any updates on the 8V?
    07 GTI
    APR stage II
  7. #87
    Oct 2010
    Quote Originally Posted by golfmeup View Post
    Well I got my 8v engine in the white car now with the cam and mk3 down pipe. But now I think the starter motor is dead, no matter what I do it doesn't seem to want to crank over fast enough. Gti imports has a spare starter for me to borrow and test out, just haven't had the time to get it yet. The car has fired up and ran a few times so I'm pretty confident it's the starter.
    Great links! The qpeng link is a great link and they also make a great down pipe. But I've read that the tune isn't the best for Australian conditions, that's why I went standard ecu and a conversion loom. Also worked out cheaper
    Golf mk2 GTi 8v
  8. #88
    Jan 2007
    Sorry I posted the links on your thread I've moved them over to my thread where I was meant to put them
    07 GTI
    APR stage II
  9. #89
    Oct 2010
    So I got the white car up and running now, but it has started to die when I try accelerate. Very puzzling and haven't been able to fix it, been thinking of trying a new distributor. Also had a weird problem with the 1.8t started idling rough and under acceleration it was a little hesitant and sounded like it was running on 3 cylinders, I swapped out the coilpack and spark plug on cylinder two as the car ran no different when I disconnected it's coil. That didn't fix it at first but after a few attempts it seemed to fix it, but I put the old spark plug and coil in and the problem had disappeared. Kind of confused to what had gone wrong, anyone have any suggestions for either engine?
    Golf mk2 GTi 8v
  10. #90
    On the white car check the electrical plug on the back of the throttle body. Mine came off and it was so bad the car would only idle, as soon as I accelerated it died. You might have a poor connection.
    Paul
