Page 12 of 14 FirstFirst ... 21011121314 LastLast
Results 111 to 120 of 140
Thread: Golf mk2 Gti
  1. #111
    Jun 2007
    Eastern Suburbs Melbourne
    I agree with Paul. Let it over flow and leave it for a few days. and see if the car holds a level. (make sure you test the same time, ie in the morning before you start it up).
    Also, you should have a fluid level indicator, that will go off if you're using coolant.
    i like volkswagens
  2. #112
    Oct 2010
    Water level drops. No visible leaks anywhere. If there was a leak with the pressure of the boiling water I think I'd see a it.
    91' Golf mk2 GTi 1.8t (soon to be gtx3076’d)
    Golf mk2 GTi 8v
    02' Audi S3 (soon to be gtx3076’d)
  3. #113
    Does the water level keep dropping if you leave it or does it drop and then stay at that level?
    If you park the car on concrete is there a water stain to show where it's leaking?
    How much water are you losing each day?
    When you see it boiling is it bubling or steaming?
    Do you have next Saturdays Lotto numbers?
    Paul
  4. #114
    Oct 2010
    Paul
    Haven't seen any water underneath it. In a couple of hours when the car is off the bottle goes from the top to middle. It's bubbling. Yes I do, but I think I'll keep them a secret so I'm the only person that wins.
    Golf mk2 GTi 8v
  5. #115
    Jan 2007
    "Double, double toil and trouble
    Fire burn, and cauldron bubble."
    Sorry couldn't help it.
    Seriously though if there is bubbling but no steam, it sounds like it's leaking air into the system somewhere.
    No visible leaks though?
    07 GTI
    APR stage II
  6. #116
    Jan 2007
    Quakers Hill, Sydney
    Have you run with the heater open?
    I once had a corolla like this & it was a really small pin hole in the casing of the water pump. Couldn't see anything until it was up to temp, then the hole opened up.
    Took my mechanic & myself nearly 6 months to find. Actually looked around everywhere with a UV light with the hope that the coolant would glow.
  7. #117
    Jan 2007
    Good tip by JonesyGT.
    07 GTI
    APR stage II
  8. #118
    Oct 2010
    Wanting to go gt28 now. Does anyone have any suggestions on the best way to do it? Buy a kit or get a manifold and adapters made up so it works with my current exhaust and I/c piping? Also any advice on fuel pump and best way to do it?
    Golf mk2 GTi 8v
  9. #119
    Jan 2007
    Did you fix the overheat problem? What was it?
    Sent from my Nexus 5 using Tapatalk
  10. #120
    Oct 2010
    Quote Originally Posted by jonesyGT View Post
    Nope. No idea, haven't been bothered to do anything to the white car.
    Golf mk2 GTi 8v
