Page 11 of 14 FirstFirst ... 910111213 ... LastLast
Results 101 to 110 of 140
Thread: Golf mk2 Gti
  1. #101
    Jun 2007
    Eastern Suburbs Melbourne
    So how do you know it's overheating?
    I'm with Paul on this one. Why do you think it's overheating?
    i like volkswagens
  2. #102
    Oct 2010
    It's overheating because I can hear it boiling the water & it's coming out of he expansion tank cap. I've replaced the cap and it still does it.
    91' Golf mk2 GTi 1.8t (soon to be gtx3076’d)
    Golf mk2 GTi 8v
    02' Audi S3 (soon to be gtx3076’d)
  3. #103
    Jun 2007
    do you have a o ring on the expansion bottle? iirc some are meant to have them, some aren't.
    The bottles are designed to have a natural overflow in them, and when you overfill them, the level automatically sorts itself out. is it possible that's all that's happening? What happens after the water has gotten out, and then the car is left to cool (ie, overnight). Do you come back to find that the level is ok? or is it low? Does the expansion bottle have a level indicator on it, factory and good OEM ones will, but some won't, and it's easy to overfill them.
    i like volkswagens
  4. #104
    Oct 2010
    No o ring on the expansion bottle. If I open the expansion bottle when the car is warmed up it's got boiling water in the expansion bottle. Coolant level seems to drop when I leave it but I can't find a leak anywhere. It's doing the same thing my 1.8t did with a failed water pump except this water pump was clearly spinning and has no sogns of wear, the other spun freely. It's not just leaking out a bit it's basically emptying all the water once the cars warm.
    Golf mk2 GTi 8v
  5. #105
    Jan 2007
    Does sound odd.
    What condition is your radiator?
    07 GTI
    APR stage II
  6. #106
    Oct 2010
    Quote Originally Posted by golfmeup View Post
    Does sound odd.
    Well radiator was on a car that over heated because of a failed water pump. Did have a lot of gunk in the system but I hosed the whole system out to clear it and it seemed fine.
    Golf mk2 GTi 8v
  7. #107
    Jan 2007
    Just a thought- as this car has overheated before, it may have had stop leak put in the system by the previous owner, it could be causing some blockage in the flow somewhere.
    Do you have a spare radiator handy? Might be worth doing a trial fit and see if same results.
    07 GTI
    APR stage II
  8. #108
    Oct 2010
    Well as fast as the hose was putting water in the water was coming out, so don't think rad Is blocked. It's got my old engine and water pump and that was fine before I took it out. Thinking it's airlock
    Golf mk2 GTi 8v
  9. #109
    Sounds like you are loosing water through the expansion tank which is normal. If the tank is full when cold it's going to loose water as it heats up because the hotter the water gets the more it expands. When it cools down it contracts and you think something is wrong because you're missing some water.
    If you don't keep filling it up each day it should still have some water in it after a few days. If it's overheating you should also be losing power when it's hot.
  10. #110
    Oct 2010
    Well I'll put it all back together today and see what happens. I do usually overfill it to make sure it's got enough water, but I still don't think that's the problem as it does seen to be boiling. I'll give it a thorough look. I have put the lid on when the water is at the full line and same thing happens, but I will re try everything now and try figure it out. Very confusing but I will slowly figure out what's wrong
    Golf mk2 GTi 8v
