Page 10 of 14 FirstFirst ... 89101112 ... LastLast
Results 91 to 100 of 140
Thread: Golf mk2 Gti
  1. #91
    Oct 2010
    Checked a few things and have no idea what fixed it. Now another problem I've been having is the car keeps over heating. Water pump seems fine, impeller doesn't seem to be lose. Thermostat works. Got a new overflow tank cap. Have been searching forums and can't figure it out. Car drives fine and doesn't seem to have any water in the oil, or oil ok the water. So hoping it's not head gasket. Anyone have any ideas?
    91' Golf mk2 GTi 1.8t (soon to be gtx3076’d)
    Golf mk2 GTi 8v
    02' Audi S3 (soon to be gtx3076’d)
  2. #92
    Mar 2012
    Eastern Subs, Victoria
    Air trapped in the system? Takes are fair effort to get all the air out of these.
  3. #93
    Oct 2010
    Quote Originally Posted by Bamish1000 View Post
    I've let the car rub without the expansion cap and it seems to let a lot of air out but still didn't fix it. Water pump is definitely working, same as thermostat. Hoping it is just airlock though
    Golf mk2 GTi 8v
  4. #94
    Mar 2012
    Try massaging/squeezing all the hoses , covered with a rag so you don't get burnt
  5. #95
    Oct 2010
    I've tried that, still seems to have a problem... Anyone have any other suggestions?
    Golf mk2 GTi 8v
  6. #96
    Run the car for a couple of minutes until the gauge shows it's warming up.
    Put your hand on the radiator, is it warm? If it is then the water is flowing through your cooling system and the gauge is faulty or the thermostat isn't opening all the way. If it's cold then you have either a blockage or dud pump or faulty thermostat.
    Paul
  7. #97
    Oct 2010
    Paul
    I ran a hose through the rad to make sure it wasn't blocked. I took the thermostat out put it in boiling water to make sure it was opening, opened fine. While that was off I ran the car and looked from an angle at the water pump which was spinning perfectly, while the car was off I also attempted to spin the impeller with no movement what so ever. The fan for the radiator does come on, but temp on dash doesn't get over half way. I'm really hoping it's not head gasket. I've squeezed all hoses and ran a hose through all hoses to try get rid of any blockages
    Golf mk2 GTi 8v
  8. #98
    Have you tried to wire up a external temp gauge to check ? as sports_racer said it could be the gauge is faulty. Head gasket failure won't cause overheat, overheat will cause head gasket failure.
  9. #99
    Jul 2005
    Is the rad fan coming on,that will tell you if the radiator is flowing from the thermostat?
    Widebody Cayman S Turbo, 83 ur Quattro
    2000 996 C4 cab,12 Scirocco R OEM+ STG2+
    72 914 (3.2S boxster pwr), 92 G60 Corrado
    76 Scirocco(TFSI and DSG) 2018 Tiguan,Eureka,81 924.
  10. #100
    Quote Originally Posted by Schalke04 View Post
    So how do you know it's overheating?
