It was Camden GTI that did the engine conversion and i'm pretty sure the gearbox was sourced from them as well. The older one seized up or something.
I will get under the car and see if I can see a part number.
Found a bonnet! Brian out at GTI Imports managed to find one for me. I'll be doing the whole front end this weekend. There is one thing that is still confusing me about the task. What is this cracked part I've circled in the photo? Is it part of the big bumper setup? It just sits behind the bumper but everywhere I've looked so far on the net, other cars don't seem to have this.
Good to hear you got a bonnet sorted !
I'll take a look later at mine (as I still have the grill off the car) and see what the part is.
I don't recall seeing on mine.
07 GTI
APR stage II
Thanks Golfmeup! That would be great. Going in blind this Sunday.
That's the reinforcement between the bumper cover and the metal bumper bar!
Looks like the bar is band and the cover has returned back to its place!
If that makes sense
2 door Golf MK2 Diesel in Poland
4 door Golf MK2 GTI in OZ
https://www.facebook.com/marcin.stop...=3&pnref=story
https://www.facebook.com/VW-mk1-mk2-...417593/?ref=hl
Had a very busy Sunday taking the front of the car apart and putting it back together.
Marcin, I get what you mean, I got a pretty good photo of it here. The metal bar was bent like you said and it was so hard to get the plastic off! Bent it back for the time being until I find a straight one.
Anyway, the car looks much better!!! Biggest problem was getting the bonnet latch to line up properly so the bonnet would lock. Battled with that for a couple of hours. Turns out the donor slam panel I bought ended up being not as straight as I thought it was! (Much better than my original though!).
Thanks for all the help with this one guys.
Will post a finished pic once I wash the car! It's all greasy.
Good work Josh, good to see your getting stuck into itLooks a lot like my garage over the last couple of weeks !
I've had the same drama lining up the latch for the bonnet too, thought it was only me.
At the moment is locked shut until I work out how to release it.
07 GTI
APR stage II
I had a similar issue golfmeup. I forced the bonnet to lock and then the release wouldn't open it up. Had to poke a screwdriver up the hole in the latch to push it out. It was jammed in there due to the misalignment. Need to have the grill off though so you can access under the latch on the slam panel.
It closes fine now after a few adjustments.
Just saw this thread. Just got a Mk2 for wrecking in the yard. That makes 2 here now.
Hit us up if you need anything.
