Results 1 to 7 of 7
Thread: golf mk2 bosch airflow sensor/ gti 1.8
    Sep 2007
    perth western australia
    hi can anyone source me a airflow sensor ? having some trouble with acceleration. its a bosch one and look like has been removed in its time, can anyone give me a guide where to get one. thanx
    How do you know it's the problem?
    I'd be testing it before you replace it. Off the top of my head, there'll be a couple of contacts that are for inlet air temp and another pair that relate to the position of the flap.
    Once you have worked out which, you can test it with a DVM on resistance. The resistance will change with the position of the flap, as you move from fully closed to fully open the resistance should change smoothly.
    If the readings jump about or go to infinity, then that would indicate a problem.
    You might find out from the wiring diagrams in the Haynes manual which does what.
    HTH
    Aug 2007
    What your symtoms mate , whats steering you to the airflow meter???? Some one has probably been messing around with the sweep arm which is very common on them - tell tale silicone around the lid of it mate.
    CHeers
    Alba European
    Sep 2007
    thats what i can see around the lid actually , so i guess its been opend and messed around with? when i change gears in high revs the exhaust just cracks like a gun shot, in the cooler weather ( earlymorning she goes good ) so i guess its the air and fuel mixture?
    Aug 2007
    Yeah the early mornings with the nice dense cool air, bit rich perhaps, how is your exhaust system mate all nice and tight free of leaks?????
    Jmac
    Alba European
    Sep 2007
    yeah mate free of leaks... the cat converter was making a rattle at one stage. when i get back from the bush im goin to have to take it in for a tune .. cheers , thanks
    Jan 2007
    Sounds like some has been fiddling with it.
    See if there are any notches they may have marked on it.
    Has the rest of the air box been modified at all?
    I know that you can put in a Bosch air flow meter from a BMW 5 series 85-86?
    (dont quote me).
    and improve your power slightly, but you may need a different filter set up.
    Other wise you can source a OEM one through your local Euro parts supplier.
    Should not be too hard to replace.
    07 GTI
    APR stage II
