Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 46
Thread: Golf GTI Mk2
  1. #21
    Canberra
    My second gear used to be nasty when cold until I changed the oil with a synthetic gearbox oil. Was great from then on.
    Euro look 2... Mk2 love!
  2. #22
    May 2006
    The head of the aussi model is identical with the european spec cars. I've put them side by side and measured them. Zero difference.
    The certain difference is the exhaust downpipe from the head. European cars had a free flow design. We got a fairly restrictive design probably lifted from another VAG parts bin. As someone here said once, this was probably a modification performed by dealers.
    In 1991 a lot of european countries did not require catalytic converters to be fitted. So the presence of the cat makes our cars different from many european cars too and retards their performmance slightly.
    Finally, in 1991 we could only get 91 octane fuel in this country. The engine management system seems to have been given a slightly different profile to make the cars run safely on low octane fuel.
    As someone has already said, change the front pipe and you get virtually the same spec as any european spec car fitted with a cataytic converter. Any retard that has been built into the ECU can be overcome by advancing the ignition timing slightly. Finally, fill it with 98 octane fuel and drive the b*gg*ry out of it.
    The main reason people say our cars are slow is because they are driven slowly. The ECU uses fuzzy logic to work out the settings to best suit the driving style. To get top performance you need to train the ECU to deliver it. This is something that can take weeks of enthusiastic driving. Since most people here are law abiding and since our limits are so low, few cars give top performance.
    Own it and enjoy it for what it is.
  3. #23
    Dec 2008
    Launceston, Tasmania
    Hey guys,
    Thanks for all the info and tips. Parents are having a look at the car tomorow and if its good and we can bring the price down i will bring it back to tassie. I have another q´s, what is the size of the stock exhaust, 2"? Would you recommend buying a full exhaust system from europe or get one custom made in aus, also which would be cheaper as i have seen jetex systems go for around $400...
    Thanks, Stef
    ----[ Finished the search for a mk2 GTI]----
    1990 Golf Mk2 GTI
    276* cam
    2 1/4 in straight through exhaust
    H&R springs on KYB shocks
  4. #24
    Dec 2007
    Perth, WA. *YAWN*...
    Quote Originally Posted by moto View Post
    Hey moto, my old mk2 GTI was an ex UK k-jet with the EV 8 valve engine. It went MUCH harder than my current Aussie spec RV car.
    The head on the EV engine does have bigger valves than the RV but i don't know about other eng codes??
    But you are totally spot on with thrashing the car to make it go better.
    My Aus GTI used to sputter and carry on anywhere over 3500rpm. One day after driving my boss' Cordoba which absolutely flew, he told me it goes well coz he thrashed it on a daily basis. So, I decided it was time to show my GTI who was boss and i drove the tits off it for a month!
    Now it goes better More power, better fuel econ, and no sign of coughing even up to 6200rpm.
    As far as exhaust goes, if you spend $400 on a Jetex system from the cat back, its not going to do much apart from make lots of noise. You can get noise for $250.
    Do it right and replace the downpipe with your $400. Changing to a high flow cat wont hurt either if you have some extra cash. Thats where the most of the restriction is.
    Hope that helps.
    Cheers,
    Wade
  5. #25
    Camden, Sydney
    Yeah I agree with Wade Moto.
    Kjet UK heads definately have much bigger valves and go much harder.
  6. #26
    May 2006
    byron bay area
    Cool
    Can anyone display this using ETKA,
    otherwise it is just hersay, as we keep going on about how terrible an Australian car is but no one has any proof to back up their retoric
    Its like people on this forum crapping on about the ECU being different to one in sunny old pommy land, which has been proven to be a complete load of bollocks
    Just because someone drops in from another country does'nt mean that they know what they are talking about
  7. #27
    Oct 2005
    Nowra, NSW
    Given that mk2 1.8L engine range from 85-115hp there has to be head difference between engines. The RV is rated at 100hp according to the Bentley, not sure if the US got the exhaust system we did on this engine though but i'm pretty sure they had cats given California is hard on emissions.
    Here we go just found valve diameters in the Bentley, HT, RD, RV and PF have 40mm intake 33mm exhaust all of which have 100hp where as the GX and MZ engines have 38mm and 33mm with 85hp and 90hp. Keep in mind the Bentley only seem to show US engines but it's a start.
  8. #28
    Camden, Sydney
    Quote Originally Posted by aliasmk2 View Post
    I`ll take a pic of the two kinds of heads Ian
    There are 3 kinds. The p*ss weak aussie ones with the tiny valves, the larger head ones as found on US cars and digi Mk2s in the UK and the big manly Kjet valves as found on the first (and best) Mk2s.
    ECU is definately different too.
    If you plug a pommie ecu into a standard aussie RV engine, it overfuels. If you put it into a worked motor with a big valve head and good downpipe, you are flying.
  9. #29
    May 2006
    byron bay area
    Question
    Quote Originally Posted by static1800 View Post
    So does this mean that an RV head has big valves?
  10. #30
    Oct 2005
    Dandenong North, Vic
    I had a quick look out of interest, and as far as I can see that 85 model differ to 86 later with same engine codes as per below.
    Year 85
    EZ, HM, EV, GZ, GU, HV 98.5mm EX.V
    98.7mm IN.V
    GX, HT 91.2mm Ex.V
    91.9mm IN.V
    Year 86, 87
    GX, RD, EZ, HM, EV, GZ, GU, HV, RF, RG, RH, RV, RP, PN, PB, PF, EZA
    91.2mm EX.V
    RD, EV, GZ, RG, PB, PF, GX, EX, HM, GU, HV, RF, RH, RV, RP, PN, EZA
    91.9mm IN.V
    MK2 GTI G60
