The head of the aussi model is identical with the european spec cars. I've put them side by side and measured them. Zero difference.
The certain difference is the exhaust downpipe from the head. European cars had a free flow design. We got a fairly restrictive design probably lifted from another VAG parts bin. As someone here said once, this was probably a modification performed by dealers.
In 1991 a lot of european countries did not require catalytic converters to be fitted. So the presence of the cat makes our cars different from many european cars too and retards their performmance slightly.
Finally, in 1991 we could only get 91 octane fuel in this country. The engine management system seems to have been given a slightly different profile to make the cars run safely on low octane fuel.
As someone has already said, change the front pipe and you get virtually the same spec as any european spec car fitted with a cataytic converter. Any retard that has been built into the ECU can be overcome by advancing the ignition timing slightly. Finally, fill it with 98 octane fuel and drive the b*gg*ry out of it.
The main reason people say our cars are slow is because they are driven slowly. The ECU uses fuzzy logic to work out the settings to best suit the driving style. To get top performance you need to train the ECU to deliver it. This is something that can take weeks of enthusiastic driving. Since most people here are law abiding and since our limits are so low, few cars give top performance.
Own it and enjoy it for what it is.
