Gearbox - replace or rebuild?
Hi All,
The gearbox on my 91 GTI is getting a bit long in the tooth and will need serious work done on it in the not too distant future.
I'm contemplating either a replacement or a rebuild but need some advice.
If I go the replacement route, what gearboxes are available? I believe finding a good condition Mk2 box will be next to impossible. Will a Mk2 box or any other alternatives fit? (standard Aussie spec 1.8 litre 8v engine).
If I go the rebuild path, where can I source the required parts from?
Are there any other options open to me?
cheers,
Goudgey
just get another goodish one from Matt at Camden GTI..
to get someone to rebuild the box, it will cost $1500-$2000.
I think Matt sells 2nd hand ones for under $1000, get one and wack in it... done.
whats wrong anyway??
i made a stupid choice getting it rebuilt because the reverse gear was competely chewed up!! should have just got another.
i got it done by someone who is supposed to be good at rebuilds, but i've had so much trouble with them since.
Yeah just bang a 2nd hand one in, mk 2 box's are known for 1st to 2nd gear crunch when cold. Might as well do clutch while your at it
- You may not post replies
- You may not edit your posts
Forum Rules
