Results 1 to 8 of 8
Thread: Gearbox code
    Feb 2009
    NSW
    Gearbox code
    Where do I find the gearbox code? I'm trying to work out what gearbox I have.
    I've looked at the underside and the last 3 digits are 054. (I think)
    It's a 1984 8v GTI.
    Feb 2009
    NSW
    Nobody??????
    Feb 2010
    hey i did a search and found this old thread. might be useful.
    http://www.vwwatercooled.org.au/f69/...odes-1916.html
    Without Your Seatbelt, You Know Your Gonna' Die!
    Project: mk1 cabriolet 20vt
    Camden, Sydney
    Underneath the box at the bottom of the bellhousing is a flat plate. What are the first 3 digits??
    Or the complete number.
    Feb 2009
    NSW
    9AO or 9OA**045 from memory. It's too low to see!
    Boronia VIC
    9A is close ratio with tall final drive & 100mm CVs. Small input shaft (22mm) and should use the red speedo gear on the cable.
    Ratios are
    3.46 / 2.12 / 1.44 / 1.13 / 0.89 with a FDR of 3.67
    Pete
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
    Feb 2009
    NSW
    So It's a good box or should I swap it out?
    Boronia VIC
    Depends on how you want to drive the car.
    For track use you'd want a lower diff ratio, for highway use that's a great box.
    7? MK1 Caddy
    12 Amarok
