Results 1 to 10 of 10
Thread: Is this the gasket set I need for the 1.8 8v Kjet EV motor?
    Feb 2009
    NSW
    That would do you, no new seals for the injectors though. I bet they are shot away originals.
    Feb 2009
    NSW
    They are. Hard as plastic. But the intake manifold has a fifth hole. WTF is up with that?
    Feb 2009
    NSW
    Ok.. Got the intake manifold gasket swapped. Man that was a fun job! I worked out the little hoop is to hold/lower the gasket in. Made it soo easy to do without fully removing the manifold.
    About to do the rocker gasket as I had oil on 2 of the intake bolts.
    Feb 2009
    NSW
    2nd Gasket round and it still leaks. Now from the other side of the engine. Going to tighten it up tomorrow and see how it goes. Should I just silastic it in place then bolt together?
    I;m thinking last resort is to take the ehad off and have a good look at the guts of the engine, maybe a new cam, heavier valve springs, a mild port/polish...
    Jun 2006
    Orange NSW
    Try using a little vaseline on either side of the gasket.. Apart from a better seal, it can also stop the gasket adhereing to the manifold and head if you ever need to take it off again, increasing the chance that you can use it again.
    Feb 2009
    NSW
    I used bearing grease and still no luck. Leaking as much as it was before.
    Adelaide hills, SA
    Check the both surfaces (manifold and head) with the straightedge.
    Camden, Sydney
    Loosten all the bolts a bit and jiggle the manifold. Maybe you have it caught on the exhaust manifold or gasket.
    Feb 2009
    NSW
    Found it! It was the stupid vac line at the back of the head that goes up to.. er.. past the manifold! Fricken hell!
