Results 1 to 9 of 9
Thread: fuel pump mk2
    May 2011
    Deception bay, Qld
    fuel pump mk2
    hey guys i have a custom fuel pump here purchased from candem gti about 2 to 3 years ago i am not sure on how to which way the fuel should flow though.
    Feb 2009
    NSW
    Hose end goes to the tank. The Banjo end goes to the engine.
    May 2011
    Deception bay, Qld
    okay thanks and what should i do about the return lines
    Feb 2009
    NSW
    Dunno. Ask Matt.
    May 2011
    Deception bay, Qld
    sorry but i don't know who matt is
    Jul 2005
    Newcastle, NSW
    Matt at Camden GTI bro.
    Perth. WA
    Tank will already have a return line somewhere, check the engine bay and locate it, then trace it back to the tank.
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
    Feb 2009
    NSW
    On the meeting head there are 2 big banjos. The one on the side is the return. The front (possibly with fuel filter) is the feed. The return usually pairs up with the feed to go down a hole in the chassis leg and come out halfway under the drivers door. It normally returns to the fuel swirl/surge tank, but you can return it to the other outlet on the fuel sender.
    Apr 2006
    Asaka-shi Saitama Japan (from Tassie)
    red line you have there....from tank. everything else in that will come post pump.
    but that sure as hell isn't a mk2 set up. with no surge tank/ feeder will mean surge loss galore in corners.......
    the return goes to the surge tank that will be basicly useless with that set up in a mk2.
    Main pump sits in a seperate tank and the return fuel goes into that, at overflow the excess will go back to the main tank.
    you will have to chuck a joiner into your system return into your main tank return.
    certainly is "custom"
    Cheers, Benny
    www.axesent.com.au
