Results 1 to 9 of 9
Thread: fuel pump cut off
    Oct 2005
    Nowra, NSW
    fuel pump cut off
    After my MkI was stolen and being written off, all i can think about is having my new car not follow down the same path. Dad told me about a good idea of having a cutoff switch to the electric fuel pump, so there is no fuel and no pressure therefore no go. Will this idea damage the injectors at all?
    I was also thinking about hooking up the starter to it aswell so it cant even kick over.
    p.s getting the car tonight YES! finally!
    Nov 2005
    Quote Originally Posted by static1800
    Just get a Kill switch hooked up. Very easy and will no way impact your injectors.
    Good to see you'll be back on the roads soon.
    MY16 MKVIIR - Option: Folded rear seats mode.
    MKI....#14....lost count.
    Camden, Sydney
    Yeah a switch on the ignition switched live, or the coil wire is the best.
    Car then wont kick or start. Just put the switch in a really random place.
    The AUDI 200 I drove the other day wouldnt start unless you pushed in the cigarette lighter
    Dont mess with the pump wiring, as you could cook the relay.
    Aug 2006
    Skye, Victoria
    Quote Originally Posted by Golf Loon
    That is a fantastic idea!
    Oct 2005
    Nowra, NSW
    i was thinking of that to, its to obvious though. I am going to make up a remote switch if i can like remote central locking but for the cutoff switch.
    Sep 2006
    Australia?
    Thats sounds like a good idea. You could have it look like a booster switch lol.
    syncro Guest
    Cut the power to the fuel pump. Much harder to find and will not damage anything.
    I used to fit these with alarms.
    I agree with the fuel pump. I've had one on my daily for 11+ years now & never had a problem. My advice is to kill the trigger for the relay, or the earth, not the power supply to the relay or the power supply to the pump. Less amp's that way & you won't burn out a good quality switch. .
    Done the cigarette lighter one before & lost the element. Had to remove everything & bridge out the lighter to be mobile again, but it is a good concept.
    Use a switch and a relay and cut the fuel pump wire and removed 30cm of wire. If the folk that certify the alarms for security, think that's OK why just use a switch. If the relay dies, why should it if it's in side the car, you know where it is to bridge it out.
Similar Threads
  1. Diesel injector pump seals
    By hiho in forum Diesels
    Last Post: 19-12-2010, 02:18 PM
  2. VR6 main water pump
    By MartiniOlive in forum Mk3 Golf & Vento
    Last Post: 29-04-2006, 12:13 AM
  3. Getting fuel in the carbs
    By worm in forum Mk1 Golf
    Last Post: 22-04-2006, 05:25 PM
  4. SEAT Ibiza conversion. Fuel Pump Question.
    By Golf Loon in forum The Lounge SEAT
    Last Post: 21-01-2006, 09:30 PM
