Results 1 to 10 of 11
Thread: Fuel Injectors
    Oct 2005
    Dandenong North, Vic
    Fuel Injectors
    I need info on the fuel injectors for Digifant 1 or 2. Does anyone replace the 2 plastic clips before and after the o ring on the bottom spray jet of the injector ? Are these needed ?
    Oct 2005
    I guess no one knows about these either ... great forum
    syncro Guest
    Your questions are too hard!
    Oct 2005
    I think they are questions where no body cares to care !
    Apr 2006
    Hobart,Tas
    Sorry aussieg60. Dont be hard on us! No, I haven't replaced said parts. Is there a problem with em?
    Tis a good forum...
    Oct 2005
    I pulled out the injectors from my G60 engine so I can replace the small O rings. There are also 2 plastic like washers before and after the O ring seal that are not listed in ETKA or the injector kit part number 030 198 031 so I'm wondering if they are needed or why did they have them in the first place?
    Apr 2006
    Hobart,Tas
    Can you post a photo?
    Oct 2005
    photo with the 2 plastic type washers by side of O ring
    Oct 2005
    dont have the number, would it be the same as any aussie delivered 8v engine ? Anyone replaced injectors on the 8v digifant ?
    Oct 2005
    Melbourne - Greensborough
    I just put the rubber 0-rings on without the plastic on, spray some lubricant on the 0-rings to let them settle in properly.
    MK4 GTI (KO4, GIAC)
    VW Kombi Ute 2ltr EFI
    Audi 90 20V Quattro
Similar Threads
  1. Diesel Fuel lines
    By smithy010 in forum Diesels
    Last Post: 18-11-2006, 06:04 PM
  2. help.. fuel problems!
    By mollins in forum Mk1 Golf
    Last Post: 07-05-2006, 02:21 PM
  3. Getting fuel in the carbs
    By worm in forum Mk1 Golf
    Last Post: 22-04-2006, 05:25 PM
  4. Injectors On My Golf
    By MK2 GTI in forum Mk2 Golf & Jetta
    Last Post: 19-11-2005, 10:26 PM
