Check the piping and see if you can locate a non-return valve. It has probably failed and so the pump cannot overcome the loss.
Hi guys,
Front washers for the wipers aren't working.
I tested the pump.. it works fine.
Cleaned all connecting points on the pump and the interior wiper stalk...
And it still doesn't work!!!
Note: front and rear wipers and rear washer pump works fine
i am thinking there's a break in the electrical circuit somewhere??
when i flick the stalk to put the washers on... nothing happens,
but if i hard wire it to the battery.. it works perfectly
It could be a break in the line.
My licence plate light has been out for a year and it ended up being a cable that had rubbed right through and snapped.
Have a poke around for a broken electrical cable. Also check your fuse? I guess you done that already.
07 GTI
APR stage II
