Hey all,
I have a pair of Recaro LS fishnets that I'd like to mount into my new MK2, aftermarket unit that was installed into an E30 previously. What are my options regarding fitting these into my car? Finding used factory MK2 Recaro rails from overseas? Aftermarket options? I'm pretty unfamiliar with the watercooled world but surely some of you veterans have tackled this problem before and can give me some advice?
Thanks in advance!
Vinny
1978 MK1 2.0 16v http://www.vwwatercooled.com.au/foru...-46488-70.html
1991 MK2 GTI 2.0 8v, white (RIP) and it's red replacement http://www.vwwatercooled.com.au/foru...gti-42078.html
1997 MK3 CL http://www.vwwatercooled.com.au/foru...ml#post1292061
2001 & 2002 Bora 4motion. http://www.vwwatercooled.com.au/foru...st-123823.html
I'm looking at going the fixed base route then adapting sliders to that. Shouldn't be too hard.
Sent from my Pixel 2 using Tapatalk
I picked up a Corbeau fix back a little while ago that i'll be throwing in the mk2. Searched for a while trying to find a bracket but it's just a pain. Probably just going to pull the trigger on a Planted brand fixed rail in a couple of weeks, best I found was around $260AUD delivered from memory. The Planted brackets are built for mk2's but universal on top
1990 Mk2 GTI 20vt - @mk2.20vt
Before you fork out $260 go and talk to a local engineering shop and ask how much to make a couple of plates.
Even cheaper if you do it yourself. I got some Cabby seats cheap and I've cut the frames. Next step is making a plate to bolt or weld to the frame that also bolts to the Recaros.
Pics?
