Results 1 to 10 of 10
Thread: Exhaust TOO loud!
    Nov 2012
    North manly, NSW
    Exhaust TOO loud!
    Hey,
    i own a Mk2 Gti 1990 8v.
    Wasnt loud enough so i removed the mid muffler awhile back and replaced it with a straight pipe. Still ran stock pipes other then the mid muffler removed.
    So yesterday i figured i wanted more sound and went to a local exhaust place and got him to cut the rear muffler and welded a straight pipe to the tips.
    So now it runs the front muffler, Straight pipes to tip.
    So now i want it to be a little quieter just at idle and going through traffic but really open up when i hit it. Any suggestions on what i do?
    Thanks
    Jun 2009
    Varex butterfly valve system?
    Nov 2012
    North manly, NSW
    There a defect arent they? Just wondering whether adding a rear muffler will lose a fair percentage of the sound
    May 2012
    how much did it cost to do this?
    any performance increase?
    Dec 2008
    Bentleigh, Melbourne
    i got the front muffler (or cat) cut out, and put straight through.
    so running mid and rear muffler. they did it for $100
    and it did feel very slightly more powerful.... every little bit counts
    car is driven daily, and no problems, has a nice burble down low. sounds heaps better than a stock 16v
    Gosford Central Coast NSW
    Quote Originally Posted by TommyG View Post
    Hey,
    Thanks
    So from the way you've explained it, you now have an exhaust which is just a CAT then straight through pipe.
    In my experience with the 1.8 8V, good sounds is to have just a rear muffler (straight through one without baffles) and thats it.
    Rear glass pack witha cat will also still sound very nice.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Dec 2008
    I thought one rear muffler is too loud and droney?
    Jul 2011
    There are a few things to consider when using just one rear muffler. It has to be a good quality one that is well constructed internally. They are a bit heavier and cost a bit more but are worth it. The cheap and light weight ones made in China are noisy. If you use a good straight through muffler with the same length and width as the oem muffler it will sound nice as gldgti has pointed out.
    Nov 2012
    North manly, NSW
    It has the front exhaust but i cut out the mid muffler and rear muffler, Welded a straight pipe to a dump tip. Crazy sound. Way to much for around town, and even to much when you hit it. When i replaced the Mid muffler with a straight pipe i noticed the idle was louder and was louder at lower rpms. So im not sure whether putting a good mid muffler will keep it quiet at low rpm and then will open up when i hit it.
    May 2012
    Collaroy
    yeah this is loud, hha
    dont get a varex whatever you do, they are dogs balls
