have you got the original exhaust or aftermarket? when i had the original one they used to allways break but as soon as i had my new exhaust put on nothings happened as of yet
I found I was replacing them constantly on my MK1 at the race track.
I tried OEM, OEM HD, OEM upgrade for Cat equipped cars, everything on the shelf at repco, supercheap etc.
Eventually I upgraded to these.
Bahn Brenner Motorsport - Exhaust Hanger w/ Chain Insert
They're a stock replacement with a length of small bicycle chain cast into the rubber.
No problems since.
Pete
7? MK1 Caddy
79 B1 Passat Dasher Project
12 Amarok
Only just realized this is in the emkay2 section, sorry about that! Same shiz anyway.
Basically a straight pipe, so dunno if it's standard, I'm thinking it's missing something.
It was loud before, with a bit of crackling, but there was pretty rapid exhaust leak between the down-pipe and manifold.
I'm hoping that the volume and bushpig-steez were mostly because of the leak.
And Jarred, I made my own hook and pulled down with all my might! I get it so close, but just doesn't freaking want to!
Maybe if I drive it to a hoist, then use my entire body weight i might be able to stretch the rubber enough...
