Judging by what I can sort of decipher from your posts & also agreeing with everyone else.
It would make it much much easier if you make your posts clearer with actual sentences & explaining your problems in point form.
That way some of use can read & interpret your info as best as possible & hopefully give you some sort of direction.
Now if these people are trying & pushing you to install EFI for nearly stock VW Golf. Its because they have not one idea between them about the system!
A good place to start would also be purchasing a book on Bosch K-Jet fuel injection as already advised & learning how the system operates.
After all. How can you start modifying & playing around with things, if you have no clue how it works in the first place?
First & foremost.
If your K-Jet system is 100% & has no problems eg. hard start, faulty accumulator, leaky injectors etc, then I'd start looking at other things. But to start off with
The system "must" be in 100% operating condition
Now! Straight away I'd be checking exactly what your A/F ratio is & just as importantly, your CO%.
In NA (normally aspirated) form I always set my K-Jet cars up with 2.0% CO. This is without any additional loads. Eg. lights on, thermo fans running etc.
Your mixture/airflow rate is all in the design of the air flow sensor bowl. If you've seen enough of them, you'll see there is differences in how they are shaped. This defines how your car adjust's its A/F ratio through out load/air flow requirements,
If your CO% is approx 2.0%, then I'd be looking into your fuel system pressure.
System pressure
68-78psi
Control Pressure
Cold (10°C) approx 15-20psi
Hot approx 49-55psi
If this is right, then you can look into increasing your fuel pressure, or as I've found & used several times over & recommended it to anyone & everyone with VW K-jet cars before increasing fuel pressures -
Install a K-Jet airflap & metering head out of a larger capacity K-Basic car!
I always recommend a setup out of a early 80's Volvo 2.1-2.2L car. The airflap is larger diameter, lifts up more (increasing fuel flow through the metering head plunger slots) & also the metering head flows more fuel to suit the larger capacity engine.
(The VW K-Jet injectors are one of the highest flowing injectors, so there is no need to go in search of better ones.)
This provides very noticeable increases to throttle response, bottom end torque & high rpm fueling. This fueling system will also be able to handle approx 200+hp in FI (forced induction) form, as I've proved with my own install.
But it has to be working 100%!
If tuned right eg. 2.0% CO your fuel consumption shouldn't increase by all that much either.
I've been using this setup for over 14+ years now & have never had a problem with it & still get high 7's-mid 8's litres per 100km. This is even with the K-Jet turbo install!
Just recently I got 440km out of 35L!!!!!. Not bad for a turbo'd car using K-Jet!
Thats 7.95L per 100km!
My K-Jet turbo build for interest sake
http://www.vwwatercooled.org.au/f55/...ild-38095.html
