Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 55
Thread: Drinking fuel??
  1. #41
    May 2010
    NQ
    Do you have a part number for the Blue Temp Sensor?
    I rang up a nearby vw supplier and was told they could not supply me with the part (due to the fact that its a South African import, with a 2E engine)
    Its just a blue temp sensor for a MK2 Golf GTI!!!
    Good to hear your cars running better though
  2. #42
    Contact Matt ( Golfloon) for the temp sensor. He sells original ones.
    Audi S3 8L - Stroker GTX3582 700bhp+
    Golf GTI 1980
    Golf GLS 1979
    www.facebook.com/etunersmotorsportau
  3. #43
    Camden, Sydney
    Quote Originally Posted by 16v_kid View Post
    Thanks Gordan, yes I have vw ones, call me on Monday with a credit card if you want one.
    Matt
  4. #44
    Took the GTI for a cruise last night and did notice a difference!
    Engine is more responsive, and it feels a lot better to drive. Temp stayed steady as well.
    Golf GTI 1980
    Golf GLS 1979
  5. #45
    A new problem has occur!
    When in a stationary position, and you want to take off, the car wont rev or make any power. It will only have enough to move at a very very slow rate. After a few seconds has gone, it will return to normal and it will pick up revs easily. What could it be? Injectors blocked or something?
    Golf GTI 1980
    Golf GLS 1979
  6. #46
    May 2010
    NQ
    Could it be the Air Flow Sensor (Or AFM) by any chance?
    I noticed the flap/door on mine was a bit sticky but nothing worth worring about.
    When the car "wont rev" how does the engine run? Does it cough/splutter or run rich (black smoke)?
    Does the rpm stay abnormally high at idle when it occurs?
    When does it occur (just randomly or when its hot/cold).
    MK2 - *Insert list of dealer purchased extra's/standard features here*
    80 series - The MK2's BIG, Sooty, polar opposite...
    HAHAHA
  7. #47
    Sorry for late response, had to take the car for a drive myself to explain the problem a little better.
    Regardless if the engine is cold or warm, when you press the throttle pedal, the engine wont respond for a few seconds, then it would return to normal. Once its moving, the engine responds normally. I don't think it would be the air flow sensor, only because once the car is moving it doesn't splutter or cough.
    Golf GTI 1980
    Golf GLS 1979
  8. #48
    Jul 2005
    Newcastle, NSW
    Check the resistances on the idle switch on the throttle body, possibly faulty.
    How fast does it idle?
  9. #49
    Dec 2008
    melbourne
    same thing was happening on mine i changed the oxygen sensor thinking it was that didnt help but my dad leaned the air/fuel out a bit on the afm and that seems to have fixed it.
  10. #50
    Quote Originally Posted by mikinoz View Post
    It didn't idle well, so we had to lift up the idle a little bit. Sits on 1500 now, only cause it would of the problem. We are avoiding to not drive the car because its dangerous to be on roads like this.
    Quote Originally Posted by 8v ggggti View Post
    How do you lean the air/fuel ?
    Golf GTI 1980
    Golf GLS 1979
